Can you let us know what channel or channels you have your flaps in?
The easiest way I found to do this is to set the ailerons to channels 1 and 5 in the Flaperon menu, then use channels 6 and 7 for flaps.
Once you do this you can then then do a Pmix from Channel 6 to channel 7 setting your second flap to work with your channel 6 flap. Then you can do a second Pmix with channel 6 as the master, channel 2 as the slave and set this to switch E. You can then set the rate to how much elevator you need when using your flaps.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
