ORIGINAL: Lnewqban
ORIGINAL: TotalWreck
Technique for installing this power 32 outrunner? Some onetold meI could use 4 long bolts, with long spacer in between two washers?
No, not long bolts there.
Just a plywood firewall between both cheeks, and having the existing engine mount as a central reinforcement.
Thanks Lnewqban That is the perfect mount. Thanks I was looking for something just that simple. And I already have the same size ply wood that I had ordred. Awesome. Now to get me a prop adapter and prop can anyone recomend the correct size prop? For a power 32? I'll be useing a 60A esc latter when I can afford one. I already know that I need a 5mm prop adapter.
