ORIGINAL: sumocrawler88
Does anyone know the specs of the Sumo Crawler motor or have a data sheet on them?
I was curious about the voltage, current limits and the gear ratio.
Pololu sells Micro Metal Gearmotors
http://www.pololu.com/catalog/category/60 and they look similar.
<br type=''_moz'' />
sorry but i dont think youll be able to find specs on the sumo crawler motor. at least I couldnt find any on redcats site.
the ones you linked sure do look alot like the one in the sumo tho.
maybe if you take the stock motor out and power it up you can try to count and get an idea of the gear reduction.
then if you want more torque (and greater throttle control) get one of those motors with a greater gear reduction.
