RCU Forums - View Single Post - Silver Swallow Pulldown
Old 02-11-2012 | 04:41 AM
  #81
Mr Cox's Avatar
Mr Cox
Default RE: Silver Swallow Pulldown
ORIGINAL: 123Cat
With this radial porting it looks like the transfer charge just goes straight out the exhaust, I might try a real steep domed piston or deflectors on the piston top ,
Radial ports do work but you may have lost most of the air-speed in the new charge, as you will really loose a lot of the crankcase pressure with the long extension beneath the cylinder.
