RE: DLE 30 high power with throttle closed!
Try readjusting the idle mixture and speed to allow a slower idle. The ignition advance I believe is 1700 to 2000 RPM. The engine will be reluctant to drop down to below advance rpm if initial idle speed is too high and the mixture too rich....causing the engine to idle too fast in flight.
Jerry
