RE: DLE 30 high power with throttle closed!
You say you have the cowl off for tuning. Can you see the throttle arm?Does it move erratically?Is there any correlation between the revs staying high and the movement of the throttle arm?If not, and you have been tuning the engine, you may have the low needle lean.
