RCU Forums - View Single Post - Engine mount for DLE 30 question
Old 02-11-2012 | 07:53 AM
blackdog1961
Default Engine mount for DLE 30 question
I have read the threads about vibration for gas engines. It seems most recommend rigid mount of the stand offs to the fire wall because the logic is the radio can be protected with padding.
The DLE 30 manual says it needs to be mounted to a shock absorber during a 2 hour (are 2 hours needed?) break in period to keep the vibration from damaging the engine....
Are soft mounts required for break in? Same question when mounted in the plane. If so, what is the best method.
If it matters to the answer the plane will be a 4* 120.
Thanks!
