RCU Forums - View Single Post - Pattern Plane Recommendation
Old 02-12-2012 | 10:04 AM
  #66
MTK
Default RE: Pattern Plane Recommendation
ORIGINAL: speedracerntrixie
ORIGINAL: Sport_Pilot
If you want a fast plane that flies fast like the older planes but is big like the newer planes, there is the Bridi Giant Kaos available from BlueJay.
There is also a 2X2 dirty Birdy available.............I can imagine that one with an OPS Maxi 30cc set up rear exahust with an enclosed pipe!!
Speed I briefly looked at the 2X2 Dirty Bird on the website. Looks very good. Let me recommend the SAP 30cc gasoline engine for that one. Rear exhaust which takes the OS140 header from Macs/Tower and ES 30G or 40G pipe. Turning a 16x12 apc, it would make a very interesting plane. The engine is superbly reliable, one I've used the previous two full seasons in current pattern.
The DB 2x2 could be built to weigh in at 10 pounds flat...power to burn at that weight. I'd build it with trike retracts tho. Just wouldn't look right with taildragger set-up
The BIG Kaos also looks very interesting but for something a little larger in power plant
