RCU Forums - View Single Post - SIMLA BUILD THREAD
Old 02-12-2012 | 12:36 PM
  #681
rg1911
Default RE: SIMLA BUILD THREAD
While playing with straightening the wing (it's probably straight enough to finish the job with sheeting the bottom), I roughed-in the front top piece over the engine compartment. (Images attached.)
Right now it still covers quite a bit of the engine. This may vanish once it's shaped. But if it is not sanded away, should I leave it as is, or should I open up the top piece more? (As it is now, I would attach an extension to the needle valve to get it into the open.)
Thank you,
Richard
ID:	1726119   Click image for larger version
