RCU Forums - View Single Post - Lado E-door actuators
Old 02-12-2012 | 01:44 PM
asimace
Default RE: Lado E-door actuators
Hi everybody,
I've got three e-door actuators for the gear doors of my UltraLightning.
I pre-ordered them together with the programmer in october and Christophe made a good job keeping me informed although they only arrived in the end of january.
Each e-door has its own board so if you want to plug more than one actuator to one single channel you need to make a multiple harness 3 in 1, or mix different channels, or assign 3 single outlets to 1 channel like I'm doing with Weatronic.
The programmer is really easy to use and let's you program a delay from 0 to 15 seconds independantly in both directions open or close.
You can also program the actuator to remain open or close after gear has extended.
I chose the 30mm extension actuators and they work very well although they are quite larger (in thickness) than same extension air cylinders.
Mauri
