I had a PM from a fellow Jug builder wanting to know about the setup for the bomb drops so I'm adding a few pictures. If you are building yours stock you will see on the plans that there is a servo next to the aileron servo used for the drop tank. On my last Jug I used it to operate the bomb drops on the wing pylons, but since I modified this one for scale gear location I had to relocare the servo and I decided on a micro servo to operate it I used some left over inner nyrod to run some very fine music wire over to the pylon locations and then up through the pylons to the bomb release. Its really quite easy to do and adds to the fun factor
