RE: 3 inch white virgin foam source ???
If push comes to shove you can glue two thinner sheets together. Just make sure the glue line is in the center of the cut, so as not to mess up the cutting. You can also not glue out to the edge. Only close to where the wire will cut and there will be no issue at all.
