RE: Top Flite 1/7 P-51 Build
Wow Nrad you sure are moving along quickly. I only have an hour or two to work on mine each evening. I just did the wing fillet today after taking a few pictures. The build is going well. I have one challenge left. I need to come up with a way to hold the cowl in place without using screw from the outside. I'm going electric and the cowl needs to be removed quickly and easily in order to plug in the main battery. I'll try to post a few more pictures.
Mike
