Repair question?
If you want to sand to a smooth edge, use the wood glue (aliphatic resin). If you use CA you will sand a depression around the glue.... CA doesn't sand. Epoxy not as bad but still doesn't sand like wood glue. You can use wood filler to fill in the jagged edges.
Good Luck
