ORIGINAL: Von Ohain
I think this thread needs some clarification, so here comes my opinion, as a Bc. S. on electrical engineering.
1. The sole purpose of the capacitor is to protect the FETs from induced voltage spikes from motor and wiring harness.
The energy storage effect is neglible in this situation, because each capacitor stores so little energy, and the motor consumes heaps of it.
The capacitors has no practical effect whatsoever on the boat getting up on a plane, when you slam open your throttle.
The huge power surge will drain the capacitors nearly instantly and the voltage drop will happen anyway with no practical effect whatsoever from capacitor choice.
The capacitors task is to work as a 1st order filter together with the resistance of the wiring harness.
http://en.wikipedia.org/wiki/Low-pass_filter
2. The inductance on the wiring harness is NOT dependent on wire length. You do not have to use more capacitors if you use longer wires.
Inductance is determined by the closed loop area of the wiring harness, and if you use long wires, all you have to do is to strap the wires close together to keep the closed loop area small, and hence keeping inductance unchanged.
http://en.wikipedia.org/wiki/Inductance
Strapping the wires together also has the effect of creating greater capacitance in between the wires, further eliminating the need for any extra capacitor.
http://en.wikipedia.org/wiki/Capacitance
3. Do not ever buy a capacitor from Castle, or Etti, or anything like that. All they have done is soldered down some very generic electrolytic capacitors to a PCB board, stuck a badge to it, and charging you 50 times the price of what the chinese OEM does. There does not exist any ''hobby grade'' or ''hobby brand'' capacitors, so don't throw any money in that direction.
4. there is a very significant difference between brushed and brushelss here aswell.
A brushed motor will produce much higher voltage spikes than a brushless because of the way that an ESCs FET will allow internal closed loop bleeding of the voltage spikes, which the mechanical commutator of a brushed motor does not.
CC, which of course is very keen to sell their capacitors, fail to mention this.
CC also fail to mention that the inductance of extended motor wires is very easily kept down by simply strapping the wires together, keeping the closed loop area down.
