RE: inverted issues NEED HELP
Have you checked the carb o ring and needle valve for air leaks? A slight leak can let the engine run on top, but be bad enough that it can't draw fuel at idle. I'd also watch for bubbles coming through the fuel line which would indicate an air leak there.
