RCU Forums - View Single Post - Futaba 18 MZ setup problem
Old 02-14-2012 | 12:29 AM
flyf3a
Default Futaba 18 MZ setup problem
Hi
To those that have already aquired this radio some help please. I am trying to setup the snap roll function on this radio with no success (was a simple process on the 14 MZ).
First problem, when activating the 2 aileron wing option and ailvator function in tail type the following channels are pre assigned using the supplied 7008 SB receiver:
Channel 1 Aileron
Channel 2 Elevator
Channel 3 Throttle
Channel 4 Rudder
Channel 5 Gear
Channel 6 Aileron 2
Channel 7 Elevator 2
However, channel 7 is the battery channel, so moved the elevator 2 channel to channel 5. Elevator 2 no reversed so reverse for correct up and down movement.
In the snap setup function activate switch SF for snap function (right down), but now find that right elevator does not want to move when snapping, all other channel work fine.
What am I missing ???
Can any of the remaining channels be used for the battery input?
Regards
Burt
