RCU Forums - View Single Post - Power Box warning
Old 02-15-2012 | 06:56 PM
Andrew Bird's Avatar
Andrew Bird
Default RE: Power Box warning
Pete,
You don't need to cut the ring. Slide the LED in to the holder with the pointy end towards the base of the LED like you have in the pictures. There's a grove in the holder which the ridge at the base of the LED can slip in to. Then pull the holder tight so the ridge on the LED sits in the grove and the ring should slip over the top and hold everything snug.
