RE: Power Box warning
Pete
If it is a 'normal' LED mounting clip all you would need to do is assemble the main body through a mounting hole slide the ring on then push led in from the rear and it should lock into place
Thats how all the LED mounting clips have worked that I have fitted but I did not use the ones that came with my power boxes
Alan
