RCU Forums - View Single Post - A6E Intruder Test Flight
Old 02-16-2012 | 04:05 AM
mselby's Avatar
mselby
Default RE: A6E Intruder Test Flight
Hi Ian,
The turbine is actually dialed back to around 60 lbs. This would fly quite well with a Jetcat 200, however I wanted the extra thrust margin for tests, as a lower powered engine is somewhat marginal on vertical maneuvers (as was the real plane)
