ORIGINAL: apereira
Page 135 is the description of the snap roll function, I know that one upside down, but nothing about the way I want to set it, I do not want to use toggle switches.
Page 160 is the logic function when available, and it is not available in the Snap Roll page, I know the logic very well too.
I will keep using Snap Roll as a condition where I have aileron AND rudder as logic and switches, and where I can also set hysteresis, I have been using it for two years now, it just sucks that such a nice radio have overlooked the snap roll function, please look at the JR 11X or 12X so you can understand what I mean, there you can set the three axis rudd,elev and ail as switches, the three of them, or just two if you want, and they can be set independently for each snap roll direction, so it is on the same page but you have to set everything again for each one. Again I will never go back to JR just for that!
Thanks for the tips.
Alejandro P.
It is not clear if you are satisfied with the end results of your setup using conditions and logic and you are not satisfied with the fact you can't do it on the Spin menu or what? Is there something you are not able to achieve ? I am curious how and why you set hysteresis? Are you referring to different on/off switch positions using the sticks?
Jim O
