8FGS Want Optical Kill on SC bottom position
I am using a RCXCEL optical kill switch on two of my gassers. I also use the idle down and throttle cut on SC so that the mid position is "normal" idle, upper position is higher throttle, and the "low" switch position is throttle cut. I'd like to use an AUX channel so that the low position of SC also activates the optical kill switch. I want the optical kill switch to only activate in the lower SC position. In one plane it works fine in the other the kill switch activates at mid switch position and low position. When I assigned the kill switch to the SC switch, I did not get a menu option of what switch position I would like to assign. Can you assist?
Sam
