RCU Forums - View Single Post - Can a tiny epoxy spot on a spinner cause vibration
Old 02-17-2012 | 01:23 PM
SpaceCowboy
Default RE: Can a tiny epoxy spot on a spinner cause vibration
It could cause vibration just like any dirt could. I think it might be more prevolent on a light weight carbon fibre spinner than an aluminum one.
Did you check the balance of the spinner & prop ?
Don't forget a single cylinder engine has vibration especially at low RPM.
A fouled spark plug could also cause vibration.
I hope this helps.
