RE: Can a tiny epoxy spot on a spinner cause vibration
It is a cardinal rule to balance your prop.
Your local hobby shop should be able to help you out with a prop balancer.
Also you can do a search on balancing props here in RCU.
Some guys will balance the prop , spinner & backplate together.
