RCU Forums - View Single Post - GP Extra 300 build question
Old 02-17-2012 | 03:39 PM
SeamusG's Avatar
SeamusG
Default RE: GP Extra 300 build question
Ilied. Iused square stock rather than tri-stock for the firewall support.
I think that you can see why reinforcing the landing gear braces is tough.
In retrospect Imight lay down a piece of 1/8 x 1/8 stock on the inside of the wing's belly pan side rails to keep them straight. Gives you a side rail to glue them to rather than depending on thin CAto tack the contact points to thin sheeting and keeping them in a straight line and keep them formed to the curve of the wing bottom.
If you want any other specific picture of a structure let me know and I'll see if I have it.
ID:	1728385   Click image for larger version
ID:	1728386   Click image for larger version
ID:	1728387   Click image for larger version
ID:	1728388   Click image for larger version
ID:	1728389   Click image for larger version
ID:	1728390   Click image for larger version
ID:	1728391   Click image for larger version
