RCU Forums - View Single Post - Can a tiny epoxy spot on a spinner cause vibration
Old 02-18-2012 | 07:15 AM
q8cub
Default RE: Can a tiny epoxy spot on a spinner cause vibration
ORIGINAL: dirtybird
If your plug is black you are running too rich. Lean it down a bit and you might reduce the vibration.
Now I have a new plug plus the muffler has a gasket. It seems slightly better but still vibrates at idle.
I ran the engine today and flew the yak a couple of flights. Just a brief hover and some knife edges and couple of loops. I noticed when inverted there is, but am not 100% sure, small hesitation in the engine. Would a rich setting cause hesitation while inverted maybe?
Also, the engine has just been broken in, and had only few flights (5-6 flights) with synthetic oil (redline 1:40 mix). And, there has not been any changes to the factory low/high needle settings.
