RE: redcat may be a mistake
Well my camera batterry is shot at the moment... But where the screw usually falls out where it connects to the knuckle is broken it split the plastic right in half the screw did fall out only because there was no plastic to hold it in! It was 41 degrees and it broke less than five minutes after being inside all day so.... I ordered the metal ones. I am not sending my esc in untill i at least get to run it a few more times, to see what else breaks. It has the servo that everyone says is junk in it so hopefully that breaks so i can send them both in! Also i took the cover off and was in a fairly dark place just to make sure and no lights work on the esc unless the truck is on
