RCU Forums - View Single Post - rate/linkage geometry
Old 02-18-2012 | 03:16 PM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: rate/linkage geometry
If you have more throw than you need, do one of two things. Move the linkage on the servo horn closer to the center. And/or move the linkage on the control surface horn further from center. Both of things will reduce throw while giving you a better mechanical advantage. IE: your servo will be more effective.
david
