RE: Silver Swallow Pulldown
Thanks for the Photo Loctite,
they can be dissapointing , mine took about 45 minutes to start this morning and when it did it ran OK but not the power of my first Silver Swallow ,
its too loose and leaking and the exhaust timing is high , for a big prop
I will make another piston and move the cylinder down 1mm and remove the sub piston and recut the shaft timing to what PE says is a good sport diesel timing 130
155 is too much
and from what I read shaft balance is a waste of time on 1.5 diesels, that dont rev , so I can leave that off
The hard part is the gas tight fit
the rest can be rough enough, and will run
The cyl ext might come off and I will put the engine on a diet and get some weight off
