<div style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; ">Insane build rampa203!<div></div><div>I'm going w/the more conventional RX-18 electronics and the motors that it came with it on mine. </div><div></div><div>Please let me know what you think about the track tension. After tightening up the road wheels and suspension arms on mine (by adding extra shims to the suspension arm mounts so that I actually
couldtighten them down w/out binding[:@]), the tension seems to be "ok" for now.... But after everything breaks in, I can see a set of track tensioners in my future (and maybe your's w/the power that you're running). And adding them will be no trivial task as those cast aluminum rear idler monts will have to be ground off[
]</div><div></div><div>Shambrick</div></div>
