RCU Forums - View Single Post - fast peak charging a Futaba 6DA
Old 08-29-2003 | 02:59 PM
Krysta
Default fast peak charging a Futaba 6DA
Hi Greg,
You should not have any problems doing this. But it is recommended to cycle the battery once in a while. This must be done outside of the transmitter as your transmitter is "diode protected".
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
