RE: What radio system do you guys use?
If you make your gas install trouble-free, you will have little to worry about with range/interference issues.
A good-fitting plug cap, shielded plug wire, keeping radio components away from ignition/spark sources, etc., will give you a better margin of safety. If you can only venture out 40-50 feet, something's not right.
