RCU Forums - View Single Post - DLE 20 issue!! Help
Old 02-20-2012 | 06:00 AM
ahicks
Default RE: DLE 20 issue!! Help
After checking the fuel as you did, I would be looking at the battery (or should I say power to ign. module?) as well.
It's kinda crazy how those ign. modules work. Higher throttle settings require more power to the module. If it's not available, it doesn't just shut down, it does it's darndest to let you know about the low voltage by running so crappy you land it....
