RCU Forums - View Single Post - Building Boards
Old 02-20-2012 | 06:19 AM
outdoorhunting
Default RE: Building Boards
Easiest way that I've found is a couple of thumb tacks & a string. Put a tack on one side of door & go directly across from it & check if there are any " low spots". Do that all the way around untill you check it from all angles.No high spots or low spost = a good building board.
