RCU Forums - View Single Post - My Discontinued Great Planes .60 Fokker DR1 Rebuild and Modification
Old 02-20-2012 | 11:53 AM
  #173
ultimate2
Default RE: My Discontinued Great Planes .60 Fokker DR1 Rebuild and Modification
[8D]O.K. Pete, I must anyway to take my time. I got the smart stripe from Tower Hobbies and really it helped to save some time cutting the ribs stich tape, and so. Also got some Dubro hinges for the rudder, as you told me, but.... when I tried to order the Hangar 9 landing gear as yours, actually they send to Spain. The problem is the LG cost only 21.49 dollars, BUT shippings from US to here from H9 is 80 dollars ¡¡¡¡¡ only for that.[:@][:'(][:'(][:'(][:'(][:'(]. Plus I must pay spanish taxes, ( 30 percent more...[:@]), so at least for now, that nice H9 landing gear is going to rest on the other side of the pond...
Today I did some painting detailing and adding some highlights to the rib stiching....
Please Pete, can you post some pics of your tail bracing. I think some photos were missing cause always that these page are uploaded I can´t see some of these photos...
Also, do you think that is possible to open a hatch between the landing gear braces, ( it should be scale to ), for the propulsion battery accces.. ?. My idea is to use a 6S 5.000 mah. TP battery; ( the same that now I´m using on the P-47 ).
Well Pete, TX, Tx and thousands Txs again for all your help and inspiration on that project.
Manolo.
ID:	1729573   Click image for larger version
