RE: DeHavilland Mosquito 81
Back again today I didn't work on this bir so much I had just receved graphics for my Stinson Reliant SR-9 so I was applying those most of the day. But I did get the wing to fit into the FUSE so I could start to think just how to and what materials to make the conneting brackets out of I will still need to cut two slots in the FUSE where the LE of the wing wich will have the bracket on it can slide into the FUSE. the other thing I will have to make is a paded spot on the LE of the radiator scoop so it will blend w/ the fuse. I'm think of some kind of alum. L bracket for both forward & aft to make the mounting brackets out of. pics will be on next post.
