RE: ys 91 4 stroke
Yep start with the brass screw flush with the regulator body and go from there. Do NOT screw it down the whole way or you risk the little spring taking a set and not functioning properly. Also make your adjustments 1/8th turn at a time and allow the engine to catch up to the changes so you don't keep chasing the regulator.
