ORIGINAL: CraigG
Just so I'm clear on this, to use a gyro for the ''aileron'' only function of elvons (i.e. one mixed control suface on each side of a delta wing configuration), you install the gyro between the rx and servos and orient the gyro in the roll axis. You would obviously need a gyro with two channel inputs/outputs, one for each side. Then just make sure the servos react in the correct direction and you are good to go? Presumably the ''elevator'' function is unaffected?
Craig
That's exactly how it is with the ACT Fuzzy Pro on the roll axis for the mixed elevons of my Typhoon.
H.
