RE: Eneloop Batteries - Charging
What charger are you guys using?
Both chargers I have used tend to false peak on these cells, current charger is
the Imax B6 (same as Hitec X2).
Also if you do a discharge test what do you set as the cell low cutoff voltage?
Any other hints? - John.
