RE: 1/4 scale F9F Panther build
The last few things I could glass were the wing roots and the tail above the exhaust. Everything else I need to do involves primer or body filler right now ,and I am not doing that in the house. So until the weather moderates I can work on the intakes. If they come to a standstill then it is time to break out the Hostetler 172. Here are some pix. of the intakes. The two areas where the blue marker is scribbled all over are the areas where I didn't want to change the shape. Although It looks like I can add a wedge of foam on the inside of the intake to add more area and it won't interfere with the fuel tank going all the way back closer to the CG..................I also sanded down the tip tanks. One more coat of primer should finish them.
