RCU Forums - View Single Post - New To Autogyros
Old 02-25-2012 | 08:57 PM
liftfan1
Default RE: New To Autogyros
You might try a Rotorshape or a foam twin rotor gyro first to get the feel of gyro flight. The twins are very forgiving. The rotorshape and c-30 by LAheli use the same rotor head and I'm not impressed though I like the balsa shear pin idea. I replaced those with 1/4" long toothpick end. The hobbyking c-30 uses a different head and blades. Use contrasting colors on each side for orientation. I like wider landing gear for roll-over stability.
