RE: Unseizing nitro engine
I would pull off the back plate and inspect the inside. If it has bearing's you will see what kind of condition they are in. You can then fill it up with a good 3 in 1 oil or fuel and let it soak for a while. If it does not loosen up with that it may just be a parts engine. Good Luck, Dave
