RCU Forums - View Single Post - asp 120
Thread: asp 120
Old 02-27-2012 | 01:42 AM
seaeagle2323
Default asp 120
Hi,
I just bought a asp 120 and got it in the mail, i am going to use it on my top flite mustang 60", i bought the plane of ebay and the guy converted it to electic, i bought a mount to fit the plane and engine and a 14oz fuel tank, i might have to drill a new hole for the throttle but thats about it, the problem i have is, i have the orginal prop spinner from thekit is this one, http://www3.towerhobbies.com/cgi-bin...XTZR2&P=ML. The engine has a prop washer and 1 nut and a 2nd nut (lock nut i belive) i also found a nut that fits on the prop shaft but i cant have the 2nd nut on then is that ok? there will still be 2 nuts holding the prop on, it has a small thread which fits a long screw that fits the spinner and holds it on i just need to cut the nut down by 1 inch and it will work is this ok?
Thanks hope it makes sense i have never used a 4 stroke nitro engine,
Andrew<br type="_moz" />
