RCU Forums - View Single Post - Knife edge tucking
Old 02-27-2012 | 06:42 PM
  #74
tomfiorentino
Default RE: Knife edge tucking
ORIGINAL: rmh
99% of the time - the cg location causes this to happen. the reason is that the wing is not working against gravity in knife edge - so the ''trims'' which cause a perfectly balanced hands off level flight, now become apparant.
Hey Dick listen, I know this thread was a while ago (so I hope you see this post!) but I have a quick question for you regarding a CG change and slaving elevator to rudder to fix KE flight.
I understand your quote above and have in fact experienced it with a Tiger 60 I flew the covering off of....twice! . So when the wing is not working against gravity in KE the trims from hands off level flight become apparent. Great. Why then, are the mixes used to fix it in KE flight still relevant in level flight as well...when the wing is working against gravity?
For example, if I remove the down elevator trim through a mix with rudder input to prevent tucking in knife, why might I still need that mix to remove down elevator trim with rudder input in straight and level to prevent a dive with rudder input. The wing forces are very different relative to gravity, but the mix is the same.
Dumb question...what am I missing?
Thank you,
Tom
