RCU Forums - View Single Post - Hangar 9 30cc P-47 Build Thread
Old 02-28-2012 | 07:57 AM
  #150
John Redman
My Feedback: (8)
Default RE: Hangar 9 30cc P-47 Build Thread
pic #1 shows the brass tube blued into a balsa block that will glue into the fuselage. You will note that about 1/16 of an inch of brass tubing protrudes above the balsa block. This will insert into the fuselage sheeting when installed.
pic #2 shows the mount installed in the fuselage. You will note the brass tubing that comes up to the outer skin of the fuselage.
pic #3 shows the antenna mast installed.
pic #4 shows the antenna mast being inserted into the mast mount.
pic #5 shows the antenna mast being used to remove the main hatch.
ID:	1733281   Click image for larger version
ID:	1733282   Click image for larger version
ID:	1733283   Click image for larger version
ID:	1733284   Click image for larger version
