ORIGINAL: Vincent
3min flights ... yawn. Its fine running in a pod setup but once its installed in something scale the intake would have to be very over sized to suck in all that air just like the old DF days.
Vin...
That's the real limitation of EDF's. Their exhaust velocity is so much lower than a turbine that they have to move a large amount of air for equivalent thrust. Since full-scale jets use turbines, most scale jets have too small of an intake(s) to perform well - at least as well as a turbine.
I was talking to a guy who was thinking about doing a PCM Models L1011 as an EDF. It would *have* to be done as a twin because you simply could not move enough air through the center engine intake - regardless of which fan unit you tried - to make it perform anything like it does on a single turbine.
EDFs are cool, but I don't expect them to replace turbines - at least not for scale projects. Even if the price comes down and the batteries get better.
Bob
