RE: Thunder Tiger 120 SE: Low compression feeling
I just went over the same problems you had and adding the pump did not help neither, I deceided to take a peek inside the engine and I found what it looks to be a coin with a hole in the center, that things is the head gasket!!!!. I removed it and the engine is running like a champ!!! I use 80/20 , zero nitro anyway.
