RE: DeHavilland Mosquito 81
Alright I'm back haven't been feeling well and can't focus on the build when I'm like that, but this morning I started to lay out the the secon half of the wing. I was smart and made all of the pieces that I will need for the seond side when doing the first, so I lined up and pinned down all of the ribs and spars. The one thing that I didn't do was cut the holes for carbon fiber tube In case I had to make a adjustment, but I did mark where they should go. Well at rib three I had to make the hole larger (you will see it in the pics) but this will just get another ring of balsa around the shaft and be glued to the rib. The shafts by the way are 5/16" arrows there cheaper and you can get them at any outdoor store that sells hunting supplies, so after making the adjustment I was back on target w/ my marks. I have about three more ribs to do befor this part is finished but I 'm taking a break and then I'll get back to it, I'll post some photos after this one.
