ORIGINAL: corch
FWIW, the second plane is often THE most crashed plane. I completely trashed mine
Probably added a pound of epoxy and posicle sticks since I first assembled it.
Oh so true!
This is one reason I second the Big Stik suggestions.
A stick is a very robust plane with a simple fuselage.
That makes it easy to repair, even though it can take a LOT of abuse.
It also handles well in high winds, letting you fly when others are grounded.
It's the perfect plane for fun flys, and you never tire of it.
A Stick is also a great engine break in platform, for other planes since the mounting is exposed.
Choose a good mount and you can swap engines on and off quickly.
