RE: JetCat Start Problem
Good Mark... Actually as per your diagnostic, it indicates that the system was working fine except at the burner side. “Your test also shown that there's no obstruction in the valve and fuel line as there's enough flow rate at the end of disconnected line.” If I’m not mistaken feeder inlet of starting fuel to the burner was the only thing you didn’t check. Now it's clear, thanks for feedback.
